can somebody help,i've installed the aio ver 1.50,and than somehow the application menu is not acceseable and than the usb port somehow is not work,because when i tried to uninstall the tweaks my usb did not read by the car
thanks for the help
i have the same problem... after install AIO, my Apps and setting are not accessible, when i clicked it my screen freeze, USB is not repsonsivedoes anyone remember or have and idea how to fix a non reponsive USB port? both of them dont respond. i just upgraded to V59 and was testing some things out. I thought i reenabled wifi and its not there. didnt run the ssh again yet and i'm kinda stuck. any ideas?
Read the last pages of AIO thread. There are several posts to your firmware.Does anyone know if the tweaks/hacks work on 59.00.441 NA N?
hi do you have a a link that explain step by step to do SSH..?Obviously, you can't use either a USB stick with a script nor an USB to Ethernet adapter.
So, you will need SSH access to CMU over wifi, or you have to solder a cable on CMU serial pins like id7 has done
Actually, I just kept trying mine over and over and eventually it worked. I think it's because I was also messing around with a bunch of images and the system doesn't have that much memory. :/i have the same problem... after install AIO, my Apps and setting are not accessible, when i clicked it my screen freeze, USB is not repsonsive
I'll keep trying.... i tried to reinstall the framework, but the usb is not accessible....Actually, I just kept trying mine over and over and eventually it worked. I think it's because I was also messing around with a bunch of images and the system doesn't have that much memory. :/i have the same problem... after install AIO, my Apps and setting are not accessible, when i clicked it my screen freeze, USB is not repsonsive
the problem is my mzd connect not in bootloop, i can enter the main menu but unable to choose... and some of the tweak are applied, i.e blue theme, so they will aware of it... i just want to make it bootloop... the wifi is active, but cant ping, besides from what i read in this forum the 513 FW has unknow password or username....A German user did the same and he had to go to the dealer. The result I don't know.
