Using serial console found on CMU. Detailed info here http://mazda3revolution.com/forums/...714-infotainment-project-515.html#post1631825
Using serial console found on CMU. Detailed info here http://mazda3revolution.com/forums/...714-infotainment-project-515.html#post1631825So how do you log in, WiFi?
Result of df -h command
Hello,Code:/tmp $ df -h Filesystem Size Used Available Use% Mounted on rootfs 477.9M 440.3M 37.6M 92% / none 8.0M 356.0K 7.7M 4% /dev /dev/ffx01p1 477.9M 440.3M 37.6M 92% / none 8.0M 356.0K 7.7M 4% /dev none 128.0M 1.9M 126.1M 1% /tmp /dev/ffx01p4 307.1M 6.1M 301.1M 2% /tmp/mnt/data /dev/mmcblk0p2 572.2M 11.0M 561.3M 2% /tmp/mnt/data_persist /dev/mtdblock5 128.0K 128.0K 0 100% /config-mfg /tmp $
what appear on console before login ? the system startup ?
You try to create a autorun script ?
Sorry about late! Because yester day i caming home too late after work, so i will try to create autorun as soon as possible and post result here.Result of df -h command
The result appear on console before login on system startup has alot of infomation, i will update in here tonight when i go home.
Thank you ID7!
If you have access to the serial console, wouldn't it be possible to boot in single user mode, mount the filesystem rw, and add a new root user?Using serial console found on CMU. Detailed info here http://mazda3revolution.com/forums/...714-infotainment-project-515.html#post1631825
How could i do this when my CMU has disabled USB, can i do this tweak with my SD Card . Or please tell me how to enable USB on my CMU.Many thanks !My new Mazda 3 came with V56 (EU-version) of the Infotainment system. As explained here, some changes that were made prevent SSH access to the CMU.
To bring back access, @mzd3-k implemented a USB tweak to bring back SSH access (thanks for that!).
However, as it replaces various system files (/etc/passwd, /etc/sshd_config), I preferred a less drastic alternative.
I've attached a USB tweak that will temporarily (until reboot) start up an alternative sshd (on port 7777) that allows you to ssh into the CMU as the "cmu" user (root, basically). From there, you can apply changes to the CMU if you like.
This tweak won't make any changes to CMU files or add new files to the CMU, it only disables the firewall by calling /jci/scripts/jci-fw.sh stop (so only until the next reboot).
The ZIP file contains a README file that outlines what you need to do to get it working. It (obviously) assumes that you have some way of accessing your car over the network (I use a USB ethernet dongle).
You can do it manually, if you want to (login via SSH), or you can use AIO for that, which was specially created for it.Total newb question. I just got my 2016 Mazda 6 GT a week ago and am new to this brand.
When I want to change my background image, do I have to reupload the entire master bundle setup each time? or is there a way to just "upload" a new background.png image?
Thanks in advance. This stuff I've read / found so far is awesome.
You could try and install the files on an SD card and see if they get loaded like an USB tweak, but I've never tried so I have no idea if it'll work.How could i do this when my CMU has disabled USB, can i do this tweak with my SD Card . Or please tell me how to enable USB on my CMU.Many thanks !
Thanks. It doesn't look like AIO is for v51 anymore? It says >=55 on the thread. I'm not comfortable enough to risk upgrading to 55 myself just yet. Are prior releases that were good for v51 hosted somewhere?
You shouldn't need to log in with username/password using "temporary-ssh-access.zip", as it works with public/private keys.I'm on 56.00.513 and used "temporary-ssh-access.zip" but root jci login and password don't work any more. Does anyone know if the login has changed for ssh access?
mount -o rw,remount /
You can use AIO 1.50 (and 1.51 test) for this FW version, but afaik, there are still problems with date_to statusbar mod and all tweaks, that appear in app menu (AA, speedo and videoplayer) aren't visible after installation.Will the AIO tweaks work for Mazda CX9 FW 58.00.250 NA N? Just bought my car and am super new to this, but dont want to brink my car. Please help me, Thank you so much!
