If you TRULY can't figure out what you're looking at, I'll break it down for you:
The picture of a crisp beam pattern whose filename is SunroofLights is a picture taken from the sunroof, of the GTRLighting Ultra LED H11 "bulbs" shining toward my garage door, with a little bit of my Christmas lights visible on the wall to the right.
The picture of a blurry beam pattern whose filename is SunroofFogs is a picture taken from the sunroof, of the iJDMtoy 60-SMD 7443 "bulbs" shining toward my garage door, with a little bit of my Christmas lights visible on the wall to the right.
The picture of a crisp beam pattern whose filename is SideLights is a picture taken from the driver side of the car, about 3 feet away from the front tire, of the GTRLighting Ultra LED H11 "bulbs" shining toward my garage door, with a little bit of my Christmas lights visible on the wall to the right.
The picture of a blurry beam pattern whose filename is SideFogs is a picture taken from the driver side of the car, about 3 feet away from the front tire, of the iJDMtoy 60-SMD 7443 "bulbs" shining toward my garage door, with a little bit of my Christmas lights visible on the wall to the right.
I took these pictures facing my garage door in order for the viewer to be able to compare the dimensions of both beam patterns.
