1 - 15 of 15 Posts
Hi All,
I have a canadian 2017 Mazda 6 GT, and I installed Tweaks from mazdacmuhacks Mazda CMU Hacks - Now My system wil boot to the main screen, i can see all the icons (radio etc.) but I can't toggle between them. then it reboots after 15 seconds. Radio is still playing though.
I need help. Wife will kill me if I cant get this fixed...lol
Thanks
Hi All,
Thanks
in order to know what happen to find the fix need to know which Tweak did you installed which caused this issue?
I installed the following one after the other - then rebooted the system
Date to Statusbar
Fast Boot (Remove Nag Screen)
Main Menu Looping
List Looping (Music sources, etc)
Only two said that they installed successfully. I can't tell you which ones installed or which one caused the issue as I had 4 USB keys, and rebooted after all installs.
It's more of a first thought dummy suggestion but did you try to uninstall them?
Date to Statusbar
Main Menu Looping
Date to Statusbar is what killed your system, it's not working for the 2017's.
Not sure how to fix (scour the forums), but some guy had the same issue and ended up replacing his cmu
We really need to put a disclaimer on the AOI thread to Alert new owners not to install Date to Status bar
you have corrupted sm.config , 15 second then reboot its enough time to pull out the sm and repair it and push it back. also you can compare the original one from extracted firmware where you can download over here same yours version..
script to pull the sm and push it . you can use same for patching NNG, only change the tweak.sh ( file location of the sm )
thanks for your reply. But I really don't know how to do any of it :crying2:
I don't even know where to start. Is this a script on a USB key?
Discussion Starter · #8 ·
That disclaimer would have been nice!
Discussion Starter · #13 ·
before going to dealer to replace.. of course don't tell about tweaks at all..
yours script in hand
delete VehDataPull folder
open Tweaks.sh with editor such Notepad++ and change line 7 to
Code:
cp -a /jci/sm /mnt/sd*/config/
it will pull SM folder. inside USB config folder, inspect it ... let see which file are inside sm to compare with Original ..
OR: try uninstall show date status bar
I've attached the Data after the pull.
I've also booked an appointment with the dealer.
help me i have the same problem since 5month i installed auto android and since then my screen is freeze can't someone do a tuto on youtube or something i understand nothing from what u said
1 - 15 of 15 Posts
