1 - 1 of 1 Posts
Hello everyone,
Picked up a spare headlight and I'm playing with a stock halogen projector and HID.
Factory projector leaves much to be desired. Stock lens is about 24mm thick, so I ordered a pair of FXR clearlenses to experiment with. The clearlens has a slightly smaller lip and is a few mm smaller in diameter, so it rattles around in the lens holder. A rubber oring around the lip of the clearlens fixes this no problem.
Anyway, it turns out the spacing mobdro bluehost kodi is off, usually you can play with the distance between the shield/bowl/lens to make the projector really focus. In the 3's case, you need to decrease the distance between the shield and lens, and the only way you can do that with this projector is to fab a new shield.
1 - 1 of 1 Posts
