1 - 20 of 22 Posts
Got my wheels finally back to me, picked up these bad boys, so in the meant time I sent them off to my powder coater, and rolled my fenders. The fronts there is a slight pull to them but I don't think that was really needed to be honest. I can't remember one of our member's screen name but she had 350z wheels powder coated laser crystal and it looked seeeexy so I used the same color so props to her for it!! :yes:
Alloy wheel Rim Wheel Tire Spoke
Alloy wheel Rim Spoke Wheel Tire
Close up on the color
Alloy wheel Rim Wheel Tire Auto part
Far shot old vs new (rears is old, fronts are new)
Land vehicle Vehicle Car Alloy wheel Tire
Fitment pics:
Tire Automotive tire Auto part Wheel Rim
Ruler Tire Measuring instrument Tape measure Automotive tire
Alloy wheel Rim Tire Wheel Spoke
Tire Automotive exterior Auto part Fender Automotive tire
Alloy wheel Tire Rim Wheel Automotive tire
Wall Yellow Architecture Wood Floor
Clears CS calipers no problem.
Tire Rim Wheel Automotive tire Alloy wheel
What do you guys think, 235/40 or 245/40? Rather not do any type of stretch tire.
**EDITED BELOW***
Had my car on 4 jacks lol, I came in at the last hour so they were wanting to leave so I had like 5 guys working on my car.
Land vehicle Vehicle Car Motor vehicle Automotive design
I went with 235/40 simply for the ease of fitment. I test fitted 245/40 and it came close, i'd say about 2-3mm clearance between the fender liner at full lock and you would need an aggressive roll and pull in the rear fenders or really crazy camber.
Tire Automotive tire Tread Synthetic rubber Auto part
Tire Automotive tire Tread Auto part Synthetic rubber
Side shots (keep in mind I've done a roll and pull on all 4
Motor vehicle Vehicle Tire Automotive exterior Auto part
Land vehicle Vehicle Car Headlamp Automotive lighting
Before and after pics.
Land vehicle Vehicle Automotive tire Rim Car
Land vehicle Vehicle Car Rim Automotive tire
Some close pics of the wheel and color of the power coat, really neat upclose!
Wheel Alloy wheel Auto part Tire Rim
Land vehicle Alloy wheel Vehicle Car Wheel
Some action shots:
Land vehicle Vehicle Car Mazdaspeed3 Mazda
Land vehicle Vehicle Car Mazda Mazdaspeed3
Land vehicle Vehicle Car Mazdaspeed3 Rim
ENJOY!!!
Damn those are hot!
I'm having the same issue with tire selection. I'm leaning towards 235/40, but @color0 is pushing for me to go 245/35. I think 245 would be best, but I'm worried about clearances.
Yeah same here, I rather much have 245/40 myself but I can pretty much eye ball it, it will rub...245/35 might just clear, barely but that size is kinda expensive and hard to come by. One of the tire shops I called said, just give them a good 3 days heads up so I can come by and test fit the two sizes and go from there on which one I would like to buy.
I'm running 245 on 8... but yah.. 255 would be best... is your car lowered?
· Aspiring Mad Scientist
The only potential hitch in that plan is that your rear wheels are still +35; no guarantees that 255 will fit back there without a lot of camber.
Discussion Starter · #9 ·
I'll have to find a shop who has 255/35 and 245/40 tires so I can play around with it. I'm still leaning towards 245/40 only cuz one shop is giving me a deal on tires and tpms gaskets.
Beautiful wheels. If your going to try 255/35 I'd go buy a cheapo nearly bald 255/35 and test fit it so you can be prepared for how much negative camber you'll possibly have to run. You might even poke a bit in the front and rear if you don't add neg camber. Better to spend $20 than to spend $1000 and possible disappointment. I think 245/35 would be a good choice and completely doable on 9" wheels although 255 is a little more appropriate.
Reactions: pdc001
· Silver Surfer
you go 255 you need fender work.. alot of it.. 245 need it too but you have as many issues as 255.. i say go with 245 and do a roll and a lil pull and you be good.. those look very nice :D
Man those wheels are beautiful, loving the powder coating. What are you going to do with your old wheels once you're all set and done?
Discussion Starter · #13 ·
Thanks everyone, yeah I'll just stick with 245/40, already had all 4 fenders rolled, fronts are slightly pulled so rears may needed it so if it does I'lll have that done. I'm keep these old wheels, not gonna lie, I kinda like my old wheels a bit more than these new ones.
· Premium Member
OK Guys, I updated the original post with INSTALLED pics. Let me know what you guys think.
Wow. That's great. I can't wait to see them at the Extreme Dimensions meet. How necessary was it to roll the fronts to get the wheels to fit? I'm putting on 18x9 +36 next week.
Edit:
Moved to the MS3 wheels and tires section.
Discussion Starter · #17 ·
Edit:
The fronts is a must but not too aggressive honestly, currently mine is pulled but we that extra room that the mz3's guys don't have.
1 - 20 of 22 Posts
