Hi,
A few days ago, my friend helped me change the brake pads on all of my Mazda 3 2014 wheels, but my pedal feels very soft since then. We just changed the pads, nothing else but we must have done a mistake somewhere.
We had a hard time removing the driver side rear caliper and we thought that maybe there was a third screw for the rear calipers, so my friend proceeded to try a few but soon realized it was just stuck. When compressing the passenger side rear piston, a little bit of liquid came out near the piston but stopped as soon as we stopped the compression.
When we had finished replacing all pads and realized the pedal was soft, we removed every wheels to check for mistakes. One screw on the driver side rear caliper, and I think it's the one holding the brake fluid hose on the caliper (not sure though), was a bit loose, so we proceeded to tight it. Also, the driver side front caliper must've been rotated when we screw it back because the brake fluid hose was a bit twisted so we unscrewed the caliper, rotated it to back the way it was to untwist the hose and screwed it back.
After we had fixed these issues, the pedal felt a bit more rigid but was still a lot softer compare to before we installed the new pads. I must've done 50 km with my car since then and nothing changed.
Should I bleed my brakes because we could've allowed air to enter the brake lines ? Or should I just give my car a few more km to allow the new pads to bed-in? Or do you think it's something else?
Thanks for the help!
JP
JP
