With the lowering springs.. 5mm was as far as I could go.
I actually rubbbed and broke a front fender tab on a dip with them while making a turn. It was an easy fix, but be careful on how far you go. Too far and you will need to roll the fenders or cut them and add a wide body kit.
Yikes. What's your wheel and tire setup? I think the H&R springs have a lower drop than my Eibachs so I'm thinking you're riding lower than I am.
Thanks. 7.5" et45 w/ 5mm spacers. Not the aggressive hellaflush, but good enough to not rub w/o tweaks on camber & roll on fenders.
Cool, thanks for the info. So your setup is a bit different in that you have a taller and wider wheel as mine but with the same offset.
Me, I like your approach Minsanity. Fender-rolling would probably be the last thing I'd ever do on a car 😐. Can you say "incipient corrosion problem"?
Plenty of people roll their fenders without problem. Luckily for me, as minsanity pointed out, my fenders are already rolled from the factory
. That said, I still don't look forward to doing any cutting.
I'm going to do as a friend recommended; get some cheap spacers from the auto parts store and test out different spacing.
