1 - 20 of 22 Posts
I picked up a 2010 Speed 3 in pretty good shape to replace my totaled `16. I had actually been shopping for a Speed when I bough the new one. This one is already off to a hell of a start and I haven`t even had it a week. It had a Corksport intake on it when I got it (which I will be swapping for a JBR and have for sale soon). It needed a little bit of TLC in that the boost bypass tube from the Forge BPV was split, and the plugs in it, while in fantastic shape, were horribly over gapped so I put new ones in just because. I slapped a set of sweet 18x8.5 et35 wheels on it, just put the Magnaflow catback on it today, springs arrive later today, probably do those on wednesday. As soon as I get the Borla from my other car sold I`ll order an AccessPort and fuel pump internals.
My first "power goal" is 330hp. I`ll probably hang out there for a few months to formulate the plan to get me in the 400whp range. It`s not hard to do, but I don`t like to have to max out any component to get results, I`d rather have the car making 385, and capable of 430 than to have it capable of 400 and making 395.
I have some pics. Maybe I`ll post a few...:wink2:
Well, here`s a "before and (almost) after". Had the black OEM wheels on when I got it, now has the bronze/black XXR 557s and Magnaflow exhaust. I say (almost) after because the springs will be arriving this afternoon but won`t go on for another day or two. The paint was a little neglected by the first owner, nothing terrible or abused, but definitely not loved. A little bit of compound here and there and she shined up nice.
Wow!!! The car looks in very good shape! :)
If you don't mind, for compound use I would suggest Meguiar's ultimate compound! It has done wonders on my Mazda 3 paint! Have tried other products but nothing comes close to what UC can do to your paint :)
Thanks!!
And that`s exactly the compound I used. It got out all the water stains, all of the dulled abrasions, and all but a few curious scratches in the roof. Probably going to give the Meguiar`s scratch repair system kit a try on those.
Discussion Starter · #10 ·
You planning for a bigger turbo? I don't think even fully bolted (i.e. intake/tip, full catless 3" exhaust, 50/50 wmi or 33% E85, and intercooler) is going to see that kind of power. 310-320 is maxed out on the little K04.
The short answer: yes.
I have since seen several folks making 320+ with the stock turbo. I have **absolutely** no intention of working the little hair dryer that hard for any longer than the shipping time it takes for the next turbo to arrive. Basically: bolt it, tune it, dyno it, see where it gets me. If it ends up at 305, cool. If it ends up doing 328, also cool. If it does 332, well then friggin` halelujah!!! LOL. The end goal is to be in the 375 range. Much more is really a waste, doesn`t translate well on a daily driver, and sacrifices reliability. I had bragging rights with a 600hp 300ZX. I`ve outgrown that chase. Now I just want a car that`s fun to drive, faster than unsuspecting mustang drivers would expect, and reliable enough for the occasional road trip (even if not as economical).
Discussion Starter · #13 ·
I am excited with your first "Power Goal", good luck. Keep us posted.
Thanks! We managed to squeeze 40hp out of a 2016 2.0L and still got 40+mpg, so I definitely see the Speed 3 responding favorably with good planning. I`ll probably do another build diary/tune chronicle thread for it, but I can`t say it`ll go as quickly as the last one LOL. The Speed 3 costs a lot more to modify!!
Discussion Starter · #16 ·
So, the Speed saga continues. Been very, very happy with it so far. Did all the things, had it tuned, etc and so on. Tomorrow the new turbo shows up. I`m going to try and install it this weekend if I get a base tune map for it in time. For those who may be familiar, I went with the BNR S4v2, which is a fairly meaty turbo. HP goals aren`t really much more than I have now, for the time being. Sure, we`ll get another 40hp out of it on the hardware on hand, but really just trying to establish a safe and efficient power band, and put the torque curve where it needs to be in order to keep the rods happy. I`ll add methanol injection in a couple of months and go for 425hp/385tq (already making that torque number). Hopefully over the summer I can get a set of rods and pistons for it and we`ll try and crack 450hp before jumping into true aux fueling solutions. Pretty sure if I can get the fuel into it we can do a safe and drivable 465hp.
Discussion Starter · #18 ·
Any updates on this? @VoodooJef
Yep. The turbo is in and it`s been running well. Hardly cracked the shell with the tune so far with a couple of hardware issues slowing us down (the methanol controller was defective out of the box and the wastegate actuator is doing 24psi on spring pressure alone. The new controller is in and working perfectly, new actuator should arrive tomorrow). Still on the first map revision since methanol, so fuel, timing, and boost maps have yet to even be dialed in. It`s making about 360hp/370tq now, with another 60 or so hp left to tune for. I picked up a workable engine yesterday to start building as well so I can really push the turbo to what it`s made for, but that`s secondary to getting the tune wrapped up for now.
I have to admit, I am loving seeing injector duty cycles below 90% at full boost with the methanol going now.
Discussion Starter · #19 ·
Tune is just over half way done and I`m pretty happy so far. Had an issue with AFR that I just couldn`t figure out and as it turns out, the SWAS system starts to interfere with the fuel and timing in a very negative way once the HP starts getting up there. It`s fixed now (bypassed the SWAS system, a process for another thread) and ripped this one today:
Discussion Starter · #20 ·
There`s more left in it, but even this isn`t safe on stock engine internals. Gonna confirm these numbers on the dyno today, then dial back the Tq until the forged motor is done in about a month. Then it`s no holds barred.
1 - 20 of 22 Posts
