1 - 20 of 160 Posts
Discussion Starter #2 (Edited)
I am assembling a parts list. It will serve as a checklist and reference. items added as needed/time permit. Feedback appreciated. Some of these items (especially fittings) might be cheaply available at local hardware stores, but I included them here just in case.
Mechanical:
Scavenger oil Pump - Turbowerx scavenger pump. Not cheap, but it's an important part that I don't want to skimp on. Needed to return oil from the turbo back to the motor. One way valve before the turbo and after the pump. T off the oil pressure, still deciding best placement for return line. The motor will be either on a switch or wired to run when the car is on. If I can find a practical set up for self contained that's even better.
Base-Model Pump
Turbo - 57/58 trim turbo with anti surge and internal WG
T3 T4 V Band Flange Exhaust T04E A R 63 Anti Surge Turbo turbocharger Wastegate | eBay
Blow of valve - Type - S with flange pipe
As much as I want noise, per tuners recommendation, I will be hooking this up to recirculate. A hybrid may come later.
Universal Billet Anodized Type s Turbo Blow Off Valve 2 5" Flange Pipe Silver | eBay
Electrics
Maf Extension Cord - My maf needs to be pre-turbo per tuners preference.I will cut the wire down the middle splice them and run the wiring through the firewall and out the access ports in the rear to the my corksport MAF.
http://www.ebay.com/itm/Toyota-Lexus-Scion-MAF-Sensor-Breakout-Harness-/252127055122?hash=item3ab3f18d12:g:I0sAAOSwI-BWIDrA&vxp=mtr
3-Bar Map Sensor for reading boost (stock only reads 1.8psi)
Heat Exchangers
Intercooler - Black IC, maybe the version with a hose/pipe kit f I determine those parts to fit my needs. Oem diesel intercooler would be great since the mounting point are already there, but it's proving hard to source. I'm going to keep searching though.
28" Black Universal Billet Aluminum Turbo Front Mount Intercooler Tube Fin | eBay
Oil Cooler - 7 row 10 an.
7 Row 10AN Powder Coated Aluminum Engine Transmission Oil Cooler Kit Blue | eBay
Fittings
New OEM drain pan to tap
dealer
T3 inlet flange - Exhaust pipe to turbo
T3 Turbo Inlet to 3" OD Stainless Steel Pipe Weld Adapter Flange Gasket Stud | eBay - Got one with a Vband instead
Pipe weldable bov flange - for recirculation before maf. Need one for the other side as well, to attach silicon hose unless I choose to go metal.
Outlet Type R RS s RZ Blow Off BOV Turbo Stainless Steel Weld Flange Charge Pipe | eBay
Inlet Type R RS s RZ Blow Off BOV Turbo Aluminum Weld Flange Charge Pipe | eBay ended up getting a different one
Oil Feed/Drain adapter kit for turbo. built in .0045 restrictor.
T3 T3 T4 Hybrid Turbo 4AN Oil Feed 10 An Oil Drain Adapter Anodized Blue | eBay
Oil pressure sensor T - Steel Looks like a good unit.
1 8" BSPT Oil Pressure Sensor Tee to NPT Adapter Turbo Honda Mitsubishi | eBay
an4(1/8 ) hose for the turbo oil feed
4AN An 4 An 4 4 8 mm 3 16" Stainless Steel Fuel Oil Gas Braided Hose Line 1ft | eBay
an4 end hose adaptors as needed
4AN AN4 An 4 Straight Red Blue Aluminum Swivel Hose End Fitting Adapter Coupler | eBay
an10 adaptor for pan tap
AN10 10 An 5 8 18 UNF Oil Fuel Line Hose End Male Female Fitting Adaptor Blue | eBay
an10 hose for turbo drain
10 An Braided Stainless Steel Hose Oil Gas Line Turbo Drain Cooler 1250 PSI | eBay
An10 end hose adaptors as needed
10 An AN10 10AN Straight Swivel Hose End Fitting Adaptor Aluminum | eBay
An10 inline filter - pre pump
Racing Ready Inline Fuel Filter AN10 10 An Blue with 100 Micron Element SS | eBay
Chinese. It will do as is for bay and manifold fitting but it wont go onto the car (if I get that far) until its rebuilt. I've already determined I will have to partially disassemble to get it in from the top. I bought a 22mm socket to remove the 02 so I can take the heat shield off and see the actual space there. Possible using an oem mani (well designed and I woukd want to keep the low end tq when not under boost helped by its design)with the cat cut and add the t3 flange/ up pipe there. Otherwisena log manifold would be a great space saving option but I'm worried about low down tq from that type. I will reference the diesel for ic piping as the mounts are all there. Oil cooler ( aside from the very small oem one) can go in somewhere, around the fan if there is space. I was looking at the barrel type, but I don't think I want extra coolant lines run.
I haven't looked at the room in a 5 yet, but in the 3 at least after the cat there isn't room to mount it on the manifold. Also where the cat starts and ends it is not perfectly round tubing. You're almost better off using some sort of aftermarket Tri-Y, and welding the flange at the end of it. It would almost be easier to run a remote setup.
The amount of low-end tq that you may lose going to a simple manifold would be negligible. You probably won't notice too much then you will hit boost.
Discussion Starter #10 (Edited)
Doesn't seem like I will be able to remove the heat shield from the stop without making it a 2piece part. Using some pretty crude test fitting I'm pretty sure a log manifold with a simple downwards facing t3 flange (no wastegate port) will give me enough room.
mani exposed
Discussion Starter #11 (Edited)
I'm currently looking for someone to fab me a simple no WG manifold pretty much similar to this I'm 90% certain if this exact disgn had the 2.5 exhaust flange it would work fitment wise. I sent a mail to ovtuned. A local on a mazda fb page who said he makes manifolds seemed uninterested when I actually messaged him.
mz 2.0/2.3 mani (also no wg)
Ford Focus 2 3 Mazda 3 2 0 2 3 T25 IHI Turbo Cast Manifold Exhaust | eBay
Discussion Starter #13
Not worried about it. It's mainly for fitting and testing. The inside of that area is fine. For that little rough spot to be cleared that band would have to be machined down even more, meaning more material removed. I work at a crematory. Our machine(s) has plenty of metal/brick parts that are heated 2000+f for hours then cooled and heated over and over. With fluids getting on them sometimes too. From my experience I would be surprised if that cracked.
Discussion Starter #14
I did not know what you meant by remote set up but I just happened to come across it on YouTube looking at other stuff.. I think that will be the route I want to go.. even better that I have extra space thanks to the AWD tunnel..
Discussion Starter #17 (Edited)
Yea, I'm going to do a remote set up. Thanks @[email protected], I had never heard of that until you mentioned it. Seems way more viable, cost effective (no turbo manifold needed) and safe (lower temp and low boost anyway) for this engine.
C&p from my pos ton mz247 I made today.
A remote turbo set up is one in which the turbocharger is mounted somewhere down the exhaust stream, rather than on the exhaust manifold. Some benefits that are attractive to me:
No turbo manifold is needed - I found that even though there is space behind the engine for a turbo (specially with a shorter manifold), no one has a head flange for the 2.5 sky and you'd be paying to have a one off manifold built (unless you build your own). Even still, it's a cramped space and most turbos will be too large to get behind the engine without partial disassembly; a hassle. Also frees up the engine bay of pipes bent everywhere. A big $$$ saver either way.
Cooler air charge - Because the turbo is further down the exhaust stream, turbo temperatures are lower (up to 500f on some applications) meaning less wear on the turbo/oil, greater effectiveness of the intercooler, all around lower temperatures and better tuning potential.
Some people complain about turbo lag on remotes, some don't (but then again people get turbo lag with a front mount turbo too). I dont give a shit about a half a second of turbo lag I give a shit that I'm getting boost lol. The oil line will need to be run further with the addition of a scavenger pump for return; not a big deal for the cx-5 as the transmission tunnel/space above the underbody panels provides plenty of routing space or space for a self contained oil system for the turbo (that will clear the yoke for the rear diff). The space on the rear axle is ample thanks to it being designed to accommodate a hitch.
Ovtune offers boost tuning and the only part that will need to be upgraded on the block is the OEM map sensor. It caps and 1.8 PSI so a better one is needed. An oem Mazdaspeed or bosch type will work just fine. Actually corksport just released and 3 bar sensor.
Basically since the majority of the work on this just exhaust style piping, with the exception of the oil return or self contained oil, once I find a shop that will give me a good price on sizing and welding up the tubing I should be good to go. It will have to move quickly from there then I will pay for boost tuning (my tune right now is only for NA) from OVtuned (or drive with the WG fully open/charger disconnected or no exhaust until I get a tune lol. I don't believe I will need a large IC, the front of the cx-5 is already sized for an intercooler (diesel)I and If I wanted I may be able to fir a small one under the rear bumper.
You might be better off squeezing a td04h in there from a subaru. They are plentiful and easy to come by.
Yea, if physical size becomes an issue that would be a good alternative. I paid $175 for this one, I'm sure I can resell it for 125 or trade it for something like an IC.
I found some 04's for less than $ 200, one is designed more standard type, cx-7 direct replacement http://www.ebay.com/itm/K04-1-8T-1-8L-Audi-A4-Turbocharger-VW-K03-KO3-Passat-OEM-UPGRADE-Turbo-/191132484689?hash=item2c80624451&vxp=mtr
and another one is for an audi replacement, but it has a slim design where it doesn't bulge much.. that would actually be ideal for this type of installation.
http://www.ebay.com/itm/96-03-A4-PASSAT-1-8T-1-8L-K04-Turbocharger-UPGRADE-TURBO-BOLT-ON-VW-KO4-300HP-/191491484276?hash=item2c95c82a74&vxp=mtr
1 - 20 of 160 Posts
