1 - 2 of 2 Posts
Hi every one
I need a little help.
I have a Mazda 3 2.0 Skyavtic-G 120 hp version, I would like to have removed the limitation and engine optimized.
Unfortunately there are not many in Denmark, which has much experience with this ..
If being updated and the restriction removed, how much can a mazda workshop look at the service and connection to Mazda and the electronic service book
Can they see any change in motor controls?
There was a discussion on this mod earlier which mentions who can perform this and what is involved:
http://mazda3revolution.com/forums/...mance/110498-skyactive-g-2-0-120hp-165hp.html
In terms of monitoring changes done from a tune, you can easily flash back to the stock tune if you have the tuning hardware and software. From what we know, a Mazda dealer cannot inspect the settings you were running prior, if you flash back to stock. The ECU should not keep any learned values after a flash. However, they may see how many times you've flashed the ECU, as there may be a flash counter implemented in the skyactiv ECU.
1 - 2 of 2 Posts
