1 - 14 of 14 Posts
Hi everyone
My FM reception has been very flaky (Random buzzing etc) and I've pretty much narrowed it down to the Antenna after much troubleshooting and testing. I suspect it's it's a faulty component on the Antenna's circuit board that's intermittently playing up.
I removed the Antenna and looked at the board for anything obvious, however the components are miniature and don't look like anything I've had experience with in the past (changed bulging capacitors etc).
I don't really want to spend $$$ on a brand new OEM Antenna so I was wondering if anyone knows anywhere I can purchase just the circuit board(s) without the fin enclosure or second hand ones? I don't care about the color as I'll keep my original.
Thanks
Sorry I don’t have an answer for you but I was wondering the other day why my car(2016) doesn’t have the shark fin antenna. Signal is good but I prefer the shark type.
Good luck!!
Good luck!!
Your car does not have the Shark Fin because you did not get the tech package which came with the bose/xm(xm requires the 'shark fin') and a few other options.
Discussion Starter · #10 ·
In Australia mine 2014 top package has no DAB. The Shark Fin is for FM. Over here the hatches have the fin and the sedans have the glass type for FM. Not sure about newer models. Anyway my issue seems to have been solved... Hopefully for good
There's no external antenna on my 3 week old Australian Mzd3 sedan. Reception on FM is fine and DAB is ok (it's clear but does drop out from time to time). I'm assuming it's all coming via the rear window antenna.
Makes me wonder why the hatch has the shark fin antenna at all.
Discussion Starter · #12 ·
I don't know but sedans have the glass antenna and the hatches have the centre roof one (be it Shark finn or a standard). May be it's for the 'sporty' look there's some technical reason why the hatch glass can't accommodate and antenna.
1 - 14 of 14 Posts
