I have a 2015 Mazda 3 IGT made in Mexico and recently it started blinking all the time that the car was not running. This includes when the doors are opened and unlocked. The manual is clear that it blinks twice per second after the car is locked for 20 seconds then the alarm is set. I've reset to the factory settings as well as my own custom settings and the results are the same. It should not start blinking the second the car is turned off, but only after the lock is engaged by the interior door lock, the keyless/FOB transmitter lock button, or the door handle optional button which mine has. My indicator doesn't blink twice per second, but once every two seconds from the time I shut off the car to the time I start the car. This was not the case the prior three years.
For the past six months I had customized the security settings to automatically lock the door when the transmitter was moved away from the car at which point it would beep to let me know it locked. This week it did not beep. The car locked, but the beep stopped and the indicator changed its behavior. That is when I tried the factory reset to no avail.
Will be taking it into the dealership next week.
