Apologizes IF this has been posted here before...
There is a problem with Connect MAP updates when installing SD CARD into PC, particularly SONY VAIO.
The VAIO's are asking user to "Please Format", under NO circumstance should you format your Mazda (MZD) Connect SD Card, If you do you will wipe card and IF you are out of new car warranty will basically render your Navigation useless, particularly IF you have not backed up SD Card in the new version Mazda Toolbox.
IF you are seeing this with your Sony Vaio, then you must use a different brand of PC to update MAPS onto SD Card.
While this does not effect all VAIO user, there are many.
Its not a fault of Mazda Connect or NNG, but Sony, they apparently are aware of the problem.
