Actually do I need to update my cambers?
Sent from my NE2215 using Tapatalk
I think the HS2's are a great cheap suspension and worth the money so I don't think you will be disappointed, adding a softer spring rate to your front like said above could be a good option to help reduce understeer with a stiffer Sway bar, I have a stock sway bar and that's Plenty for me.
I feel you wont notice a crazy issue with understeer unless you're really pushing your car, I could be wrong, I found the HS2 6k F/5k R spring rates to be comfortable, I couldn't imagine having 8k+ spring rates like some of these coil overs come with, that's for super static low boy things lol. When you start to increase the dampening past 20 on the HS2 struts you can start to tell how stiff the springs are, increasing the dampening will make the car have more bounce due to stiffer strut compression.
The HS2 coil overs come with a front upper camber plate so you don't need anything for the front unless you plan to go lower that 2.5" that's how low I went and after alignment my camber is at -1.5 all around, if you go lower then maybe camber bolts would help, but if you do need to adjust the front camber you'll need to do so with the suspension back out or cut the opening of the upper strut support in the engine bay, when they are installed you cannot access the camber bolts to loosen the upper camber plate because the opening is to small,
Also something to pay attention to when installing the HS2's is the two lower strut mount bolts can be moved in and out a little before tightening.
ex: with the suspension installed and all bolts loosely in place, snug the top but keep them loose on the bottom, you can grab the rotor and push it in and out and you'll see the mounting points move, idk how to explain it, but think of it this way, pushing in before you tighten them down would give you more negative camber and pulling out before tightening would add positive camber. I pulled out as far as it would go and then tightened the lower two bolts and I didnt need to adjust the upper camber plate.
As far as the rear camber adjustments go I've heard nothing but good things about the Megan Racing rear Adjustable camber and Toe Arms but i've never used them, and if you're not going to slam your car i'm not sure that you would need adjustable rear camber and Toe arms. I knew I was going to slam my car so I got them lol but in the past i've used Megan Racing parts and never had a problem with them, and on that note I would 100% recommend the front upper strut brace by them, I love mine.
the HS2 coil overs come with Godspeed Project front endlinks, take them and throw them in the trash haha get a better quality Adjustable endlink, well that is if you are doing to go low low, which you said you didnt plan to, so if you're doing a mild drop of say 1" - 1.5" I think the supplied endlinks would be ok, but I'd still get better ones in general, if you do go lower than 1.5" I've been told rear adjustable endlinks are necessary but if not then I don't think you'll need to add those. I doubt the Godspeed parts will last long or even through a winter. I do not like the Godspeed front or rear adjustable endlinks and they will be replaced in the future.
