1 - 6 of 6 Posts
Just out of curiosity, does my 2017 have a built in command start that gets unlocked via a bypass module? I've seen some info on starting via the oem remote by hitting the lock button 3 times and then it shuts off once the door is open. Am I way off base here?
You would have to add the remote start package, and i believe its a different remote?
I prefer DEI remote starts with alarm, they do so much more!
Do you know if it's possible to wire it to fire up the heated steering wheel via an auxiliary button? My sales guy told me the heated seats remember the last option used which is nice and hope is true.
If i leave my heated seats on (2014 3 GT) they will be on when i remote start the car, so i would assume yes. No extra wiring needed. Same with AC/Heat.
My aftermarket DEI remote start will also remotely open and close my windows.
can you give some more details on your system maybe a link to it?
does the engine shut off when you open the door like the others?
Thanks Matt
Thanks Matt
Its really awesome. Lots of mods you can do but it has remote start and break in alarm, even notifies the fob if there is a break in or if your car is hit up to a mile away. Remote start works from a mile away as well.
As i mentioned i can also remotely close/open my windows. Awesome if i forget to close them in the rain.
I also have a security cam with motion sensor.
DEI is basically the company that owns all the good remote start systems like Python and Viper.
This is the unit i have: Python - 2-Way Security and Remote Start System
1 - 6 of 6 Posts
