Just bought a 2015 hatchback. The rear wiper bangs into the spoiler/shade at the top of the arc hard enough to stop it unless I force something under the shade to raise it a fraction. Anybody else had this problem?
I have this one as well. Be aware this is for the Japan build hatch. The part is different for Mexico build hatches according to Bosch.This is the Bosch replacement. You can check the length:
Nothing wrong with visiting the dealerships part department for this, but here in the states the rear blade is easy to get. I bought mine at autozoneI suggest you visit your nearest dealership. Depending on your country, Aftermarket rear wiper blades may be hard to find so you have little to no choice but to buy one off the dealership. It has to fit in flush with the plastic housing otherwise you'd get the problem you mentioned. From my own experience with cars, the rear wiper blades wear out faster maybe because I use them often even when they're dirty. Back then I don't clean the dust off it as often as the front wipers but now I make sure I clean all of my wiper blades regularly.
