1 - 6 of 6 Posts
Hello!
Question I have the Eibach Sportline Springs.
The front looks PERFECT. But the Rear Height is a tad too high...Maybe need it .5" - .75" lower....
My Question is can you trim the Stock Rear Bump Stop at all?
Or are there aftermarket Rear Bump Stops that come slightly shorter than OEM???
Thanks in advance!
You can trim them up. I believe there are a few members on here who have. Hopefully one of them will chime in. As for aftermarket... I haven't seen any out there.
Sent from my iPhone using Autoguide
Ground control makes shorter bumpstops that are 3" vs 5" for the oem. You need to Gorilla glue them into the upper mounts because the diameter is smaller. I use the soft one's for my rear shocks.
Fat Cat Motorsports also make bumpstops but they're super expensive.
Ground Control - Foam bump stop ($12.00ea)
1 - 6 of 6 Posts
