I have a 06 Mazda 3 and it has a rattling noise when I accelerate. Sounds like a transmission mount. Anyone have any suggestions.
wow thank you. I think I got that farOpen the hood and look maybe?
OK, so if you have the hood open, just look to see whats making a noise. Listen to find where the noise is coming from. There are several possibilities.....usually its a loose heat shield on the down pipe. Nobody can diagnose a noise they can't hear or a broken part they can't see.....wow thank you. I think I got that far
Very true. I was trying to upload a video but I can’t find out how.OK, so if you have the hood open, just look to see whats making a noise. Listen to find where the noise is coming from. There are several possibilities.....usually its a loose heat shield on the down pipe. Nobody can diagnose a noise they can't hear or a broken part they can't see.....
Typical Flux Capacitor, The flux capacitor requires 1.21 gigawatts of electrical power to operate, which is roughly equivalent to the power produced by 15 typical commercial airplane jet engines, at lower gigawatts there is the possibility for a rattle or knocking noise.i think it's the flux capacitor
Hard to say, that video would be helpful for sureI have a 06 Mazda 3 and it has a rattling noise when I accelerate. Sounds like a transmission mount. Anyone have any suggestions.
is there a way to add video here?Typical Flux Capacitor, The flux capacitor requires 1.21 gigawatts of electrical power to operate, which is roughly equivalent to the power produced by 15 typical commercial airplane jet engines, at lower gigawatts there is the possibility for a rattle or knocking noise.
I've seen people post videos but they are youtube links, not sure if you can direct post a video, @arathol ?is there a way to add video here?
under what conditions are you hearing it? Only under acceleration or can you also get it while in park?This is what mine sounds like just not constant.![]()
FIXED: Mazda 6 grinding/creaking noise on acceleration - SEE DESCRIPTION
FIX:I had recently replaced my serpentine belt. Autozone sold me a belt that was 2mm too long. This was the issue. The belt was simply too long. This caused ...youtube.com
