841 - 854 of 854 Posts
Necessary Maintenance
Hello, I have a 2013 mazda3 i with 52k miles. I live in Florida if that is relevant. Is there certain maintenance that is actually needed? Of course the dealership is recommending all kinds of fluid flushes and A/C refresh, etc. What is actually needed now or soon? Is it normally about time for brake service? Other than oil changes/wheel rotations, the only things i've done are new tires and battery. Thanks!
Coolant flush/replace, brake fluid flush/replace , replace transmission fluid and clutch fluid, if your brakes have not been serviced they probably will need it too.
If you are relying on the dealer to service your car honestly, you need to rethink that. I hope you have not been paying the dealer to keep your tires filled with nitrogen.:surprise:
No, i really don't trust the dealer, or other places either. I usually turn down whatever they suggest, but now that my mileage is getting a bit high, i figure it's time to get some services done. I might switch to firestone anyway since i used them for new tires and i have lifetime rotations for free. Thanks for the info, i will probably get those things done next time i get an oil change.
Another questions about maintenance, for a 2013 mazda3 i with 60k miles. What are these things the dealer is recommending, and do i need them?
Fuel service
emission service
evap service
a/c system refresh
Thanks in advance!
Hi!
I have just test driven a 2012 Mazda 3 skyactiv with automatic transmission, and I have a quick question for y'all.
Is it normal for the transmission to noticeably shift? I'm not sure I would call it shaking, or stuttering, but I could definitely feel the gears shift up and down. The shifting down felt a little like when you slow to a stop in a high gear with a manual transmission -- that stuttering just before the car stalls.
In contrast, I test drove a 2015 model, and it was super smooth. Should I avoid buying that first one?
My 2013 Mazda 3 does that. The transmission also delays before shifting into drive from reverse.
Not a smooth transmission at all
Hi!
Its normal
Hello I’m trying to find out what size of tubing is used for the mazda 3 2015 headlight washers as need a new bit
Average Fuel Economy Monitor displays only one reading since I picked up the car without updating and the menu bar with navigation icons won't open. Also, I've followed the steps listed to change the volume of the beep when locking the doors with no success, any suggestions?
I purchased a 2010 Mazda 3 that had been in a wreck with damage to the passenger front quarter panel. Damage involved the washer reservoir and the power steering pump. The connectors and wires were sheared off. I have figured out the power steering pump and the motor to the windshield washer. However there is another connector with the windshield washer motor, but it looks like it has a dead end plug - maybe for side lights? washer level sensor?
Other question is: there is another large connector with 4 wires (green, black, white and orange). Does anyone know where that connector goes?
Thank you in advance.
