When you replace your stock bars with larger bars, are the new bushings and brackets larger too? . If the brackets are larger, doesn't it mean the mounting holes on new larger brackets will not align with mounting holes on the car's frame? Unless the new bushings are the same size as the existings but thinner to accomodate the larger bars and therefore the new brackets are also the same size as stocks.
Can some one confirm? I am still trying to figure out, without seeing, if MS3 bars will fit standard Mz3.
Thanks
Thanks
