1 - 7 of 7 Posts
Hey Guys!
I bought the original shims for my Mazda 3 2017 front brakes for renewing my brake pads, the shims installation is quite self explaining i would say. But one question is left, which side from the inner shim part goes towards the pad? they have a green and a brown marked side, and the service manual doesn't say anything about it..
I add a picture where you can clearly see what i mean, you see the green side there.
275562
Thanks a lot in advance for your help!
Having done this several times, you'd put the silver bigger ones on and the smaller black shims overtop. They aren't super snug so expect a little slop. The caliper will hold it all together.
The green ones I'm not sure....either the pic is wrong or there has been a part revision. These appear to be just front pads? There's two shims (a big a and a small) on the back of either pad so the number of shims is correct. Just the colour seems different.
But yes as mentioned it'll all be very obvious during disassembly. Usually new pads and shims come with instructions so read them over before diving in.
I had the same situation today, previous brake pads didn’t have the shim kit to use as reference. Spoke to a Mazda service department and they confirmed the green side of the shim goes against the back of the brake pad.
2018 Mazda 3 GT
Just got a set of EBC green stuff 2000 brake pads and they came with this shims and retaining clips. :)
1 - 7 of 7 Posts
