This might be a small question, but I have poured over my manual and searched the forums and read through several unrelated threads hoping to find an answer.
I recently purchased a 2011 Mazdaspeed3 with tech package in Velocity Red. I love the proximity key and the push button start. However, sometimes a good song is on and I want to shut the engine off but finish listening to it. However, turning the engine off automatically turns the radio off, also, then takes several seconds to turn back on in accessory mode.
Turning the engine off with the push-button start gives you two default options... press once to shut everything off, or otherwise, press once to switch to ACC and again to turn the engine off. I do want to leave it set to ON->OFF. What I'm trying to find out is if there's any way to leave it as is and still switch the car directly from ON to ACC so that the engine turns off but the radio/electronics remain on.
Does anyone know if the ON->OFF sequence has an override to go from ON->ACC? Or is changing the default shutoff sequence the only way?
Thank you for reading and for any help you may provide.
