1 - 1 of 1 Posts
Want your Mazda to handle like a track car? Add the new CorkSport Mazda 3/Mazdaspeed 3 Rear End Links to your suspension set-up to get the most from your rear sway bar. By dialing in your turn-in speed and stability you are able to make your end links a tunable component of your ride!
The CorkSport Rear End Links are a rock solid, precision designed piece developed to eliminate binding and preload on your sway bar and provide you with the highest level of adjustability.
We went with sealed 31degree ball joints to keep wear and tear at a minimum for this essential part of your suspension tuning and used Depositioned Black Steel for a long lasting finish and durability.
With +/-10mm of adjustability, you can vary the lengths on either side of the vehicle to stabilize your car or allow for a particular handling set up for performance purposes. The bar can be pretensioned if you drive a track where there are more turns in one direction or you can lengthen the end links to help the bar from rubbing when moving to different adjustment settinga that are closer to the twist position on your aftermarket sway bar.
For a part that adds that much adjustability to your car and a price of only $99, getting a set for your ride is a no brainer.
Check out our product listing for additional details or to purchase today!
1 - 1 of 1 Posts
