Mazda 3 Owner
I'm trying to start the Mazda Toolbox application on my Mac, but it crashes almost instantly. The reason it's crashing is because of a server error that occurs when the app tries to check if there is a new version of the app (the error isn't handled properly, so the app crashes).
Anyone having the same problem? FWIW, I'm using the latest version of the application.
More technical info: the app makes an HTTP GET request to http://zippy.naviextras.com/services/selfie/rest/1/update, which returns a 405 response ("Method Not Allowed"). Because of this, the app tries to show a dialog, but it does so on the wrong thread, which crashes the app:
Code:
2017-10-12 10:39:07.075 Mazda Toolbox[73397:10765166] *** Terminating app due to uncaught exception 'NSGenericException', reason: '-[NSAlert beginSheetModalForWindow:modalDelegate:didEndSelector:contextInfo:] may only be invoked from the main thread. Behavior on other threads is undefined.'
*** Call stack at first throw:
	0   CoreFoundation                      0x9437627b __raiseError + 187
	1   libobjc.A.dylib                     0xa0cc76f2 objc_exception_throw + 273
	2   CoreFoundation                      0x94376195 +[NSException raise:format:] + 133
	3   AppKit                              0x927fcff5 _NSBeginModal + 160
	4   AppKit                              0x9238a808 -[NSAlert beginSheetModalForWindow:modalDelegate:didEndSelector:contextInfo:] + 249
	5   Mazda Toolbox                       0x0006e785 -[SelfUpdate showAlert:] + 221
	6   Mazda Toolbox                       0x0006e8d0 -[SelfUpdate showCheckServerError] + 112
	7   Mazda Toolbox                       0x0006f945 -[SelfUpdate runBackground] + 251
	8   Foundation                          0x95a22fde -[NSThread main] + 39
	9   Foundation                          0x95a22d78 __NSThread__start__ + 1262
	10  libsystem_pthread.dylib             0xa174c047 _pthread_body + 184
	11  libsystem_pthread.dylib             0xa174bf8f _pthread_body + 0
	12  libsystem_pthread.dylib             0xa174b84a thread_start + 34
The hostname zippy.naviextras.com resolves to two IP-numbers for me: 80.249.174.80 and 80.249.174.16.
Mazda 3 Owner
Can you elaborate this? I've facing the same issue. Thanks!
In the system-wide network settings, I had an HTTP proxy server active, which was causing the problems. The proxy settings can be accessed (assuming that you're on a Mac) through System Preferences > Network > [the active network interface, typically "WiFi"] > Advanced > Proxies.
