1 - 20 of 25 Posts
Pearl White Zoom!
Anyone have access to a previous generation Speed 3 to see if the seat mounts are the same as our 2010+ 3's?? I wonder if the airbag plug is the same too?
I routinely see good prices on these and wonder if they would fit.
I found a set of the 2009 seats with Alcantara for a great price locally, and am not sure I want to let them pass by!
Hope they fit and it works out for you. While I was waiting for delivery of my car the dealership loaned me a 2008 and the seats were much more supportive.
All 2010+ S Models have the same seats, and can be had for a lot less money.
Pearl White Zoom!
I have a friend who put the first gen MS3 seats without much trouble into his '11 i Sedan
Any pics or details? I'm not purchasing a set until I am sure. Do you know if the airbag plugs were the same?
Pearl White Zoom!
Discussion Starter #7
Just an initial follow up in case anyone is contemplating this swap.
Emailed Kidos friend and he said that 3 of 4 bolts are direct if you use the Speed rails, not sure if switcing rails is an option yet. Drivers seat electrical plugs right in but passenger side does not.
I should have my new seats bolted in tomorrow afternoon and will post more info as it comes available.
Thanks Kido!
looking fwd to seeing this done..
Pearl White Zoom!
Discussion Starter #10 (Edited)
Front and rear seats are in the car. The rears are a direct swap and fit great.
There was no way for me to tell which airbag wire was positive and which was negative, so initial testing and the light is still on, so I guess I have the passenger side backwards since I tested it with the 2010 drivers seat still in.
Once I get the passenger side wires correct, that will tell me which is which for the drivers side.
All the sensor wires are connected on both front seats. Those were the easy part.
Sorry for the lack of progress. I have been working on the stereo and a new GT rear bumper cover.
This was before any cleaning/conditioning:
D/A
Thanks Kido!
I'm a little confused? Any difference in passenger wiring? Did you have to solder anything?
looks sweet man. if i didnt have leather seats i would do this
Pearl White Zoom!
Discussion Starter #13
No soldering. The front seats came to me rather cheap and had no wiring on them; just the sensor module. I transferred over the two harnesses and the seatbelt/harness. The airbag wires were cut. The airbags are still there and functional, just needs rewiring.
This is a unique situation to the set that I bought. If you buy some with the wiring still intact, I think you might just be able to repin the plastic connectors to fit. Wires appear to be all the same, just the plastic connectors that they are in changed from 2009 to 2010.
So I'm thinking about swapping out the drivers seat on my '12 Mazda3 Skyactiv 5-dr. The lumbar portion of the stock seat is problematic for me. I'm a little unclear as to the results of the above project. Specifically, it says the rears are a direct swap, but doesnt say anything about the fronts. Does the drivers seat require modding, or can I bolt it right in?
Thanks in advance,
Pearl White Zoom!
Discussion Starter #16
Thanks in advance,
Mine came from a 'custom' Honda track car so the front feet were welded, so mine took some work. The wiring is not direct either.
Its been awhile since anyone posted in this thread. Im looking for a set of seats for my Mazda 3 2.5 Hatch. The seats in it currently suck. They have no lumbar support and they just don't have enough bucket, so I feel like im always tilted forward which causes me no end to back problems.
Will the Previous Gen im guessing Gen 1 2010 fit in a 2011 Mazda 3? Are there different Generation 2011s?
Should I just go with an after market seat and try to rig the airbag with a resistor? If so any suggestions?
I can answer this, as I have researched the topic extensively and implemented a solution.
All the seats in the current generation 3's (2011-2013) are the same, with the exception of the Speed seats. The Speed seats are electric and are not compatible with the manual models (ie. you cant adjust them).
Previous generation Speed seats DO fit in the current model 3's, but not perfectly. 3 of the 4 bolts match up and work fine. The fourth bolt, the outside rear bolt (under the B-pillar), does not line up. The airbag connectors are not compatible. The tracks from the different seats cannot be changed (in an attempt to resolve the bolt matching issue).
After learning all this, I decided to go ahead with the swap. I have a 2013 Mazda3 hatch with a 2006 Speed3 drivers seat installed. I tightened the 3 bolts and the seat feels secure; no wobbling or whatnot. The red airbag light on the cluster comes on intermittently (interestingly, its a random pattern). To me, it is not intrusive or distracting. I am pleased with the swap.
The 2013 Mazda3s are out already?
1 - 20 of 25 Posts
