Fair enough, and I know exactly what you are referring to as I've been running manuals since I learned driving, but I am pretty confident this is not due to the way of shifting gears. Again, there is no issue with jerking after disconnecting the battery. Also, it's very inconsistent, sometimes jerking is very subtle and other times more intense.That bucking is the clutch and transmission. Its from dropping the clutch when its trying to revmatch, my advise would be know the gears a bit better, for mine its 6k 1st gear to 3.1k 2nd then 6k 2nd to 3.1k 3rd, then 6k to 4th is 4k
If that doesn't help try to just hold a tiny bit of throttle before lifting the clutch or when decelerating hold the clutch right before bite point so it revmatches, then downshift, hold the clutch, shift, ect. You will literally feel the car click into gear once the clutch and transmission speed matches in the correct gear.
Also theres almost no way to stop bucking in 1st when downshifting from second unless you hold the throttle slightly to keep it at 4k the let off the clutch. The way i do it wears on the clutch more but i find it safter in an emergency then rev matching the traditional way.
