Hi Fam,
So I was a knuckle-head and didn't disconnect the negative terminal from the battery while I was installing the HID relay to the battery. I was tired and had a long day at work. ( no excuse )
I am ok! Thank goodness. However I dropped a ratchet on the battery and unfortunately the ratchet landed on the pos terminal and touched this piece below.
Burnt a hole and I need to replace it.
First off what is this piece? Where might I be able to pick that piece up? There is no damage if I keep driving with it covered right? (Covered currently with aluminum foil)
If this part is expensive, what could I do to repair it?
For the future to any of you. DONT BE DUMB AND BE ME. Disconnect your negative terminal before working on anything with the battery.
Thanks,
-G
Thanks,
-G
