has anyone installed an indash gps system and needing to place the antenna? where did you place itand how did you wire it? I need some suggestions.
Im thinking of keeping it inside the car like placing it like under the rear view mirror withdouble sided tape, but im scared it wont get the signal it needs.
if theres a way i can get it through the front window rubber part i would.. but i cant. without taking the window off...
any ideas?
I just place the GPS antenna on the dash. I tuck it in the lower corner of the dash and it is held by double sided tape. There is no need to place it outside.
My GPS antenna is mounted in the dash behind the trim between the two centre vents.
Pat,
Awesome.. thanks! thought the glass would interfere with signals. whoot! did ya'll by any chance get the rear view camera too?
