1 - 13 of 13 Posts
Celest Zoom-Zoom
Got my corksport springs last night. Rear is done. The fronts not so much. I got the new springs on the strut assembly but cannot for the life of me get the assembly back into the knuckle. Does anyone have any tips on how to do this. I have had two people trying to do this and neither has been able to do it.
Your going to need an alignment after. But which part are you having trouble with?
When you say you cant get it back in. Is it that it's just impossible to get in or it won't line up?
If it doesn't fit get a bigger hammer
Reactions: VRM Speed3
Use a jack, lots of lube, and move it back and forth and it will slowly slide in
Stick a piece of thin metal into the slot and then reverse thread the 17mm bolt in to spread the ears a tiny bit. Grease the bottom of the strut and it should slide in easy. Don't spread the ears a lot or the bolt won't lineup with the threads later on when you go to torque the assembly.
Works for almost everything... everytime
Reactions: StaFForD
1 - 13 of 13 Posts
