Hello I have a p2188 code coming up. I had the transmission and tstat replaced 2 weeks ago. My maf sensor is only 4 months old but I cleaned it anyway. My evap purge valve seems to be working it opens and closes with 12v applied. The car is 2004 mazda 3 2.0. I have been getting a random p0455 also.
Fuel Status = 0 byte
Engine Load = 48.235 %
Engine Coolant Temperature = 195.8 °F
Fuel Trim Bank 1 Short Term = -9.375 %
Fuel Trim Bank 1 Long Term = -20.312 %
Intake Manifold Pressure = 5.366 psi
Engine RPM = 732.5 rpm
Speed (OBD) = 0 mph
Timing Advance = 2.5 °
Intake Air Temperature = 105.8 °F
Mass Air Flow Rate = 36.016 cfm
Throttle Position(Manifold) = 12.549 %
Run time since engine start = 296 s
EGR Commanded = 0 %
Fuel Level (From Engine ECU) = 36.078 %
Distance travelled since codes cleared = 84.506 miles
Barometric pressure (from vehicle) = 14.214 psi
Catalyst Temperature (Bank 1,Sensor 1) = 1,009.94 °F
Voltage (Control Module) = 13.68 V
Engine Load(Absolute) = 34.118 %
Commanded Equivalence Ratio(lambda) = 1
Relative Throttle Position = 3.529 %
Absolute Throttle Position B = 12.549 %
Accelerator PedalPosition D = 7.843 %
Accelerator PedalPosition E = 8.235 %
Speed (OBD) = 0 mph
EGR Commanded = 0 %
