Hi guys,
I got a manual 2.5 M3 GT. Usually when I shift through the gears, the shifter goes into the gear slot (from neutral) with 1 smooth notch and that's it, like it should in an ideal world. However, sometimes I feel like there is a 2nd notch as the gear leaver travels from neutral into gear. It doesn't grind or get stuck or need any extra effort - it still goes into gear no problem, it's just a feel I get in my hand. So when shifting from neutral into gear, instead of the usual singular "clunk" it feels like a double "clun-clunk".
Here's a video from youtuber MotoMasterX5 where I see/hear the same behaviour. If you pay attention to his downshifts into 2nd, you'll notice that the gear leaver jerks ever so slightly as it goes from neutral into second. It happens at 0:42 and more prominent on 1:18 (Sorry, I can't post links yet):
youtu.be/H6A2YPNl1Qg?t=42
youtu.be/H6A2YPNl1Qg?t=78
Here's the same phenomena on a WRX Subie on 0:31, while shifting into 1st (more prominent) and then 2nd (you can hear it):
youtu.be/2s4fIxvI68M?t=31
Has anyone ever notice that? Is that an issue or am I OCD-ing like crazy here?
If you're still reading:
I noticed this behavior on other cars as well. I used to own a Civic with the same symptoms and I drove my friend's 2018 Mustang with similar feel in the shifter. In 2015 I test drove a 2.0 M3 and it also had the same feel. But I just can't help but wonder - is this normal or do I have an issue with my tranny? Most of the time it happens when downshifting into 2nd and almost never happens if I shift from 1st to 2nd after 3000rpm. So it's almost like the car is asking for revs >
I know a bit about a manual transmissions, so it may just be the gear sleeve sliding over the dog teeth of the gear. The gear is rotating at the same speed as the sleeve (due to the synchro), but there is nothing to align the teeth of the gear to the slots in the sleeve. So that occasional notchiness might be the sleeve hitting the misaligned teeth, aligning them and going in.
Any thoughts?
Any thoughts?
