Update #2:
I ordered a pair of metal plugs (M12x1.0) for the master cylinder so that way I could do a quick test without having to remove it from the car just yet. Removing the fluid lines from the MC and inserting in the plugs, I decided to go about testing the brake pedal feel in two ways:
Onto the test with the car turned on...the pedal was as squishy as ever (would still rise back up, but the same audible air sound and squishiness I've been experiencing throughout this bleed job). Again, it wouldn't pump up to pressure either. Same when I turned the car off, still wouldn't pump up to pressure like it usually did before plugging the MC.
I'd like to point out that in both conditions, the brake pedal didn't "drop" under its own weight, or fall to the floor after applying a set pressure with my foot. The main issue is that it just failed to build any pressure while testing the MC.
Would love to hear any comments/thoughts/feedback/advice etc.
- With the car switched off
- Switching the car on, letting it run for about 5-10 seconds before turning it off.
