if your running 0w-20 the oil is too thin and most likely why your seeing the oil level warning, the oil pressure is too low and oil consumption up from the oil thinning out.... Since the car is turbocharged it needs to run the *w-30 weight oil.. the 30 weight is very important for the turbocharger and engine design with the amount of heat output from the turbo when at any boost level and the oil is at temp..... 20 is too thin.. If you want the cold 0w rating use 0w-30
I also had a friend with the turbo 3 get the same message "Oil level Low" his oil was at the correct level.. What happened was his Mazda dealer put 0w-20 in by mistake two days before when he had his 1st oil change he noticed on his bill.. So he went back they changed to 5w-30 for free.. no more Oil Level errors as well. Thankfully I do my own oil changes.
But good to know the ECU picks this up early.
Pic from 2021 Turbo 3 Canada/USA manual below.
