so thank you very much for thread.
becareful with rhino ramps.I found my Rhino ramps on Craigslist, think I paid around $25. Only needed for front.
Can you post a video.....um....maybe we can have a look and see what you may be doing wrong? :Michael_Jackson_danbecareful with rhino ramps.
i drove my car off them. :frown2: :surprise:
i tried again, and did the same thing.
what am i doing wrong??
Drove off them? Like straight off them? Get someone to guide youbecareful with rhino ramps.
I would have done the oil change much sooner. I do not think anything was harmed but what many do not realize is the engine if full of assembly lubes and also other things that really should be removed around the 3000 mile mark?Was wondering... The dealer told me that my car is due for an oil change every... 8000km or 4 months
This would be my first oil change, would you guys suggest getting it done earlier to flush out all the crap from breaking in the engine or wait till 8000km
Edit: I'm at 1800km so far.
The level is going to appear higher if you check it when the car is warm, and it will appear lower if you check it when the engine is stone cold. You want to have it between the two holes. If it's ever appearing below the bottom hole, it needs oil.Sorry to revive an old thread but I've been having issues reading my dipstick after almost every DIY oil change I've done. My 2.5L engine calls for 4.8 Quarts to replace the engine and filter oil. I purchase a 5 Quart bottle and empty out .2 Quart into a separate bottle, leaving me with 4.8 Quarts left. I remove and drain the old filter and well as let the oil drain out of my Fumoto valve. I fill the new filter to the brim with oil out of the remaining 4.8 Quarts and then top off the engine with the remainder of what's left of the oil.
I warm up my car, wait about 5 minutes for it to cool down, then I remove dipstick once to clean it, insert it again fully, and check my dipstick to get a reading. The problem is whenever I check my dipstick, the reading is never at at obvious marking point. Sometimes I see a buildup near the low indicator, and other times I see oil trailing up to about 2 inches higher than the "full" marking. Is this normal - or what the fk am I doing wrong? I've attached a few pictures but it's pretty hard to see the oil. 🤷♂️
Any help is appreciated.
Cheers
