I helped Razerer install OEM side skirts yesterday. It was pretty easy to do, but took us 3.5 hours to complete. We were taking our time and trying to be thorough. Measure twice, drill once. The instructions that come with the parts are straight forward, so this won't be a full how to. These are pics to just help illustrate:
Here's the part number for the white skirts.
The OEM side skirts:
Cut out the drilling location templates:
There are lines on the plastic to help you align the templates:
Use a small amount of tape to affix the template to the skirt. It'll make for easy removal of the template from the skirt later on.
Use tape to hold the skirt in place temporarily, so you tape all the templates to the car.
Slowly pull the skirt away and the templates should come off of it easily.
Drill the holes at a slight angle. Start with a 3mm bit, move up to 6mm, and end with a 10mm. Use a file to clean up the holes.
We used touch up paint in the holes to help prevent rust.
Put on all the clips to the side skirts.
Put on the side skirts. Some of the clips may require a little force to get into the hole.
Step back and enjoy your handy work.
Edit:
Here are the instructions.
Edit:
