This is for the 2018 Hatchback, but likely similar for all generation 3 models. Sorry in advance for the long post.
First some simple questions. I would appreciate informed first hand responses instead of the typical "I read somewhere..."
Question 1: What is the efficiency of the non-Bose woofers without any additional amp. xxdb at 1w/1m is the general reading, or if you personally made an A/B comparison, what was the results. Ie: I installed the Infinity model xxx and they were slightly quieter at equal volume than the stock. Also include for subjective impression of bass response. I will get to the reason further on. If you used a phone SPL meter or RTA to support your findings, please add them in.
Question 2: What is the TRUE RMS rating at 1% THD for the non-Bose stock HU? I have looked almost endlessly, and have found no facts. There are youtube videos of a guy testing actual amp power, but no stock units. As near as I can tell, 13 watts RMS at 1% THD, but only found opinions.
Now for my reasons and possible ways to create a very simple budget upgrade that yields excellent improvements:
Many have noted that aftermarket speakers improved the sound, but often had less bass. I have not heard comments on volume differences though. By knowing the true factory SPL rating, you will know in advance the volume improvement potential (if any). Obviously for those adding big amps, this is irrelevant, but this forum is for stock head unit only. Many of us just want to fix the major shortcomings without breaking the bank or turning this into an extreme project.
I ran some pink noise frequency response tests on the base unit, and the problem is clear: There is a 20db drop in the octave or so around 5kHz. 20db drop basically means you don't even hear that octave. To isolate the problem, I tested the woofer alone, and after 5kHz, it just goes wild up and down.
Solution A: This can be tamed with a simple 0.25mH-0.35mH coil connected to the woofer. Same bass, just no wonky. And you keep the higher efficiency and the hassle and cost of changing it. If someone can provide a wiring diagram (does it go first to the dash, then the door?), the coil can be installed in below the tweeter without ever taking a door panel off!
The tweeter tests makes the woofer seem like great quality. A 6db slope strait up to 10kHz and then back down the other side. A pyramid shape if you will. We have all heard of single note subs. Very common. Well, Mazda has a single note tweeter. It is absolutely useless and no hope for using this tweeter. Sad thing, Mazda has used this same garbage tweeter and mediocre woofer ever since the Mazda 3 came out. Our old 2006 was the same. Shame, shame.
Solution B: Perhaps the best fix is simply a 3.5" replacement mid/tweet with a 10uF cap to keep the impedance curve safe (although a have no FRD or ZMA files to test it in Xsim). Once I start the project, I will test if the tweeter polarity needs changing to be in proper phase with the two 6db slope crossovers.
Combine Solutions A and B are easy, inexpensive, and may yield the best bang for the buck.
Solution C: My last possible solution is to use the highest efficiency component system possible. Has anyone tried the Hertz K 170? They claim a 93.5db at 1w/1m efficiency. If this is true, then the 13watt at 4ohm non-Bose head unit powering the Hertz K 170 would have more sound output than the highly rated 88db Alpine S-S65C teamed with the Alpine KTP-445A Power Pack Amp that is rated 45watts. Remember that each 3db of output requires a doubling of amplification. Be careful on the SPL ratings. If it states 88db at 2.83volts, if it is a 4ohm speaker the power is really 85db at 1w/1m. And the Infinity REF-6530cx is rated at an impressive 93db, however it is at 2.83v at 3ohm, equal to approx 88-89db at 1w/1m. Not nearly what you expected.
Food for thought. Please chime in if you have fact based answers to my questions. Sorry again about the long post.
