I was super exited today to install one of those front tow hook license holders that attach to the front tow hook.
Well, after I took the plastic cover out, I found out that my car doesn't have the socket. Is that a standard thing for 2014?
https://i.imgur.com/X9FxmIZ.jpg
Note: Yes I know those aren't actual tow hooks and just shipment holes or whatever they are called.
Rubber side down
I haven't made any attempts to pull those bumper covers off, but in your picture it appears that there is a plastic hole plug that might be removable. Perhaps it is behind that?
nope, that's metal there (about 7 inches deep) with a slight indent where the hole in the metal was supposed to be.
Rubber side down
Huh. Well, you got me. Unless it is a removable piece, I haven't the foggiest. Break out the drill and tap?
Edit:
For some reason I cannot see the picture you linked anymore, but you say there is an indent where the hole should be. That leads me to believe that there is a threaded stud welded on the other side of that piece. I bet that there is a special tool required to rotate and unscrew that part which would reveal the threaded tow bolt hole. Just a guess. Either that or the indent is due to a weld that completely blocks off the threaded hole. One or the other. :p
