1 - 8 of 8 Posts
Just an observance, but it dawned on me that our Turbo 3 doesn't have factory fog lights. It is definitely no big deal, as cars' factory fog lights are often minimally effective anyway. But most cars with higher trim levels usually have fog lights, it just seems to be the normal thing.
File under "first world issue". ;)
Foglights are a completely worthless feature on a compact sedan IMO. Based on prior experience with my 10th gen Civic, they are barely noticable vs. standard headlamps, and are just another glass surface to shatter after catching a bit of road debris.
2021 Mazda 3 Turbo
Where did you buy those aftermarket DRL lights from? Do you have a link?
They're available at a lot of different places, like Aliexpress and Amazon.
If you do decide to get it, you should be aware of the QC issues (it's a relatively cheap Chinese product). I've had to buy two sets because water leaked into one of the LED housings, destroying it. One of the LEDs from my second set also failed due to another water leak. I had to disassemble and apply silicone sealant to prevent ingress problems.
There are also no instructions included, so you need to be pretty familiar with working on your 3. You can always reach out if you need help.
Ah yes I wasn't sure about the quality of ones on Aliexpress, adding some sealant to prevent water ingress is probably a good call.
I wasn't sure about the wiring, could you help verify if I got it right?
LH: Yellow wire (F20) for positive, light green (F24) for turn signal
RH: Sky blue (F21) for positive, brown (F25) for turn signal
1 - 8 of 8 Posts
