1 - 2 of 2 Posts
Premium Member
Details:
The New JBR TRU-3.0 & 3.5” Wide Path Full Intake Systems are the only True 3” intake systems that extend from the MAF housing all the way to the transition at the turbo. Currently, all one piece metal intakes that are available from our competitors are 2.87” or 3.37" and all the other aluminum intakes that include a separate billet MAF housing start out at 3” but then quickly neck down to 2.87”. Our one piece design eliminates the need for unnecessary couplers and the joining of multiple sections that increase turbulence and friction which ultimately leads to reduced airflow. The thick, 5-ply, wire reinforced high temperature silicone construction is far superior at insulating the intake air from extreme engine temperatures. This translates in to lower boost air temperatures and more horsepower that no other aluminum intake can accomplish.
Every TRU-3.0 & 3.5” MAF housing has been machined from 6061-T6 to tolerances of +/-.001 and include a factory style air straightener for the most accurate signal to the MAF sensor. The air straightener is integrated in to the wall of the housing eliminating any reduction in ID like those that use honeycomb straighteners. There’s also no way for the straighener to come loose and be sucked in to the turbo like those that use pressed in blades. Our MAF housings are the lightest in the industry weighing in at only 9.1-9.8oz. The lighter housing significantly reduces heat soak, sheds heat quicker which lowers intake temperatures creating more power. Each MAF housing is beautifully anodized for a smooth, long lasting finish resistant to corrosion, even when subjected to the harshest environmental conditions.
All Tru Wide Path Intakes now include a 3.25” or 3.75” Dry-Flow air filter. JBR Dry Flow air filters flow 200% more air than the factory filter while providing superior engine protection. It uses both depth loading, capable of removing extremely fine particles (down to < 0.1 micron), and structural screen wire to enhance airflow capabilities. This design results in a performance air filter capable of increasing horsepower and torque! The three-dimensional synthetic filtering medium is washable and requires no oiling for years of trouble free service.
The Wide Path Full Intake system is designed to be run in recirc mode but, includes a plug for easy conversion to non-recir mode.
Includes:
Tru-3.0 or 3.5 Silicone Intake System and Billet Aluminum (3.0” ID or 3.5”) MAF Housing
Stainless T-Bolt Clamps
Plug to run in non-recirc mode
3.25 or 3.75 Dry-Flow Filter (Washable uses No Oil)
Installation instructions are available in our support section
Shipping is free in the US & our Hassle Free Lifetime Warranty is included
Admiral Obvious
too bad you don't have a trade up program.
1 - 2 of 2 Posts
