Hi and welcome!
Kindly check the records to see if maintenance is done right and on schedule following the owners manual. Nothing too special, just make sure engine oil and oil filter is changed regularly. There are lots of things that need to be inspected such as suspension, brakes, steering, and more. You could do it yourself or have a trusted mechanic help you out. Also, while you're at it, inspect and lubricate all the bushings and make sure your filters are clean (you might need to replace your fuel filter if it hasn't been done before).
Take care and drive safely!
