I've already got the itch to start the modding. Never owing a mazda before, what are some good aftermark sites to check out? I'm happy with power, but would like to upgrade suspension and brakes. Also what are some of the more popular mods for these cars?
https://www.tirerack.com/content/tirerack/desktop/en/homepage.html
The best modification you can do is lose those boat anchors that Mazda calls 18" sport rims. :w00t 1:
Those things are 50 lbs each with tire mounted.:crying: Good lightweight rims will make a significant improvement in how the car drives. A good set of 17x7.5 or 8" rims with 225/50 tires can get you a net loss of 15 lbs or so of unsprung weight on
each wheel. :surprise:
Oh, and you
will need tires in any case. The OEM Dunlops are garbage. :thumbsdown 1:
As to the suspension, H&R, Eibach and Racing Beat springs are popular additions, each with its own properties. There are many dampers available from any number of makers. Bilstein has some good ones, and Koni has a couple popular choices. The Koni Yellows have a following among the sport competition crowd but are a bit stiff for daily driving. Koni FSDs seem to be a good upgrade. While you are into the suspension don't forget to add a larger rear sway bar and stronger endlinks. A larger rear bar is usually the first thing that many owners do to their car.
There are extensive threads on springs and swaybars in the sticky section of the suspension subforum .
There are not a whole lot of brake upgrade options. EBC has a couple performance pad upgrades. CorkSport has a big brake kit but its way overkill for street driving. I've seen some drilled / slotted rotors out there but not sure of the quality of those.
The larger brakes from the Mazda 6 are another option as they will fit with some small modifications.
A short shift plate kit is a nice addition. JBR Racing and CorkSport both carry similar pieces.
Don't get sucked into the cold air intake hype. SRIs look neat and sound cool but in reality they do very little. They can actually cause a hp loss due to heat soak, drawing in hot under hood air and causing a large spike in intake air temps. :frown2:
Aftermarket exhausts are fairly common also. There are several good ones out there. Check out the performance subforum for stickies and numerous other threads on the various exhausts available.
