I have 4 led bulbs, front and back turn signals and the 2 side-brake light.
The seller sent me a 50w 8-ohm load resistors for the hyperflash issue
As you probably know, the space in the front is near impossible. Very tight and no space. I read other users had to remove the front tires and such.
The back turn signals looks doable, I could succeed in putting the load resistors.
Will this fix hyperflashing issue ?
** When i first installed back turn signals (front turn signal still OEM), it was working fine, no hyperflashing, it's when i put the front led turn signals, where everything started hyperflashing.
