Hi!
I have some questions and need help! I'm installing Tein H Techs tomorrow, and am confused on the cutting the bump stop part (I'm a noobie for this kind of stuff:/).... So I know one cuts it 30mm for the front, and 35mm for the rears (recommended to cut fronts and rears) .
1). So do we measure it from the top and subtract 30/35mm and then cut?
2). After we cut it, what part do we use? The top only, or still use both? I read that for in cs springs that the larger portion goes onto the strut piston... is that the case for H Techs ( @minsanity )? *Do we discard the bottom part then?*
3). What about this chart?
Bump Stop Trimming - TEIN USA Blog
The figures A, B, C, D.... do you know which one is for the Mazda 3?
Thanks in advance!
Just measure & cut from the bottom. Like figure A in your Tein blog. Put the top part back & keep or discard the bottom part. :)
Yes! Thank you Mr Minsanity!
