1 - 2 of 2 Posts
Hi
I am trying to understand the logic with the boot cycle of the MZD Connect.
A full cold boot takes between 28-32 seconds on my CX3 dependant on disclaimer time.
If I then shut down and start the MZD with ACC (not starting car) it will boot very fast, this seems to last for about 15-20 (possibly longer) minutes then a full boot cycle occurs.
However if I am starting the car fully the period before it does a full reboot is much shorter ( under 10 minutes)
Does the MZD partially shut down then fully shut down at set timers after running ?
Would like understand the logic .
Thanks
Discussion Starter #2
Someone must have some idea as to what causes a full vs quick boot.
Does starting the car force a full restart after. X minutes ?
I know acc has a shutdown timer of something like 25 minutes, does the system only partially shut down then fully shut down after a timer to save power.
What conditions invalidate the fast start,,,,,
1 - 2 of 2 Posts
