141 - 160 of 214 Posts
It work with me perfectly , but when i tried 2nd time look like some files were missing including background, now my screen is stuck on boot, i can still hear the radio but its not loading, what can i do to fix :( please help me
1. Yes, if you have official AA/CP already, you are able to use it afterwards.
2. No, touch for AA can not be enabled via AIO Tweaks or this ability here.
3. AIO Android Auto Tweak does not support FW 70 or 74. So, yes, if you want to use AA at FW 70 or 74, you have to use the the official version (new usb hub and 2 new cables).
hi, my current FW is 30.00.300. Is it possible to AIO Tweaks to get android auto without getting a new hub/retro fit kit?
Glad I was able to help, feel free to send anybody that needs help my way
привет, помогите пожалуйста установить твик mazda на fiat, у меня сейчас версия 74.00.324, а этот твик для версии 70. на моей версии он не запускается, подскажите пожалуйста как это исправить, спасибо
Hi everyone,
With thanks to @w4rch1ld , I have been able to successfully rebrand my system back to Abarth. However, there is an issue that I have noticed on both my test bench and my car (2 different CMUs).
When trying to add a device via Bluetooth, the system is unable to do so - the "Add New Device" option is greyed out. I've tried resetting the system etc. and this hasn't changed on both units. This isn't a big issue for me as I use wireless CarPlay but can be for someone else.
I tried disabling CarPlay, WiFi, unplugged everything and it still occurs. Reading online, some people have had this issue with earlier firmware.
You need to update to 74 before. If you need help I can provide you some assistance but everything that I can provide for is in English.
I am getting many people who are Tweaking 74.00.324A, Do not it is not stable, WiFi and Bluetooth instability.
Thread closed.
Hi Ash8,
Just bought a Mazda Axela Hybrid. Its a 2014 and the media centre says it has 74.00.324 JP M.
We live in NZ. As I understand, we need to update to the ADR software for it to work in English. if correct can you send me file or link to download please. I presume we still need to follow you directs as explained in the forum. (Mazda CONNECT MZD Firmware ,CP/AA, WCP, Help 74.00.324).
Does it matter if I only have a Mac and not a windows PC?
Yes, you can update to FW 55 or 56 (if you find it) and install AIO Tweak Android Auto. From 59.00.502 onwards you are blocked to install AIO Tweaks. It will not work at FW 70 or higher. But the AIO Tweaks Android Auto is buggy and not as stable as the official one with new cables/usb hub and FW 70 or 74.
AIO Tweak Android Auto -> touch works (but the tweak does not work with FW 70 or 74 and is less stable than official one and is not developed since years - it was a user project)
Official Android Auto -> no touch
Hello, do you have an updated AIO Tweak Android Auto for firmware 74.00.324? I would like the touch screen to work while driving, and turn on without warning, and without turning on the handbrake.
Thanks for sharing! In that case, I'll consider installing new hub.
Just want to report my results in trying this:
Setup
2016 Mazda 3i Touring
OEM CarPlay + Android Auto module installed by the dealership recently (Didn't come with wireless CarPlay)
OS version 74.00.324 NA N
macOS 15.5 on an M1 Pro, 16GB flash drive, 2.4Ghz wireless keyboard with USB adapter
Results
Worked like a charm! Followed the directions and it worked as expected. CarPlay works, but do not have an Android device to test AA. System didn't have wireless CarPlay to begin with so can't report if that works or not.
This mod does not seem to work:
- Pause on mute
Attached an image of the current config I'm using as well as the OS screen plus a photo of it in action with a background.
Thank you @aeromiata for this. So excited to have the touchscreen now while in motion!
How do you get the option to change custom backgrounds in the infotainment system? i opened the casdk/apps folder but theres nothng in it. No app.background folder and no list.js file. I been trying for a couple weeks to try to figure it out but no luck.
