81 - 100 of 215 Posts
FYI - I had issues with an original wireless carplay CMU (with FW 74) and installed Speedometer Tweak. It was rebooting one to 2 times after some minutes.
And I heard about issues when tweaks were installed with installed 3rd party/non-genuine usb hub with wireless function or wireless adapter. Just that you heard about it. I do not have further details.
So to me it sounds like that the pretty old tweaks from AIO 2.8.6 are not fully compatible with the latest wireless hardware.
My wireless Carplay cannot connect after installing the Mazda AiO tweak. If you can fix it, please share with me. Thank.
@Njazda : If you have doubts and fear the risk, I would recommend to not install AIO tweaks. Honestly, the CMU/MZD works without tweaks. They are just fun - and do not let "fun" ruin your running MZD. Read about it a lot and decide for yourself.
@DaRUSTA: Disable WiFi at your computer, then start AIO again.
FYI - I had issues with an original wireless carplay CMU (with FW 74) and installed Speedometer Tweak. It was rebooting one to 2 times after some minutes. And I heard about issues when tweaks were installed with installed 3rd party/non-genuine usb hub with wireless function or wireless adapter. Just that you heard about it. I do not have further details. So to me it sounds like that the pretty old tweaks from AIO 2.8.6 are not fully compatible with the latest wireless hardware.
How many tweaks there are for FW 74xx?...i did the upgrade in my Abarth Spider but it boots now with Mazda logo, if the weather is better ,i will upgrade the hardware...and where do i find them?
Hello
My friend have 59.00.545 system version and he have aio tweaks (speedometer)
we want update firmware to 74.00 version Can we do it right away or do I have to uninstall the current aio tweaks first?
A firmware update usually should remove all tweaks automatically.
If you want to do it manually, use AIO Tweaks at your computer and tick all tweaks in red, compile, install in the car. This should remove all tweaks e.g. prior to a firmware update.
@Kurt Abarth124 :
It was a user project and is not develeoped any further since years. Back then FW 74 did not exist. No tweak was officially tested with FW 74 by the AIO developers. All on your own risk. I heard a lot about issues with 3rd party wirless usb hubs/adapters - if you install one of these, I would not recommend to use AIO tweaks.
i try to update today but its loock on "preparing to update" like 30 mins... i think need first to remove all tweaks but have question: current system version is 59.00.545
i need to any changes in rush.sh ? like elif [ $_VER -eq 70 ] change to elif [ $_VER -eq 59 ]??
Can I use the cmu150_NA_74.00.324A_update.up to re-install or I need another file for that purpose? I lost wireless carplay after using MZD-AIO tweaks, already tried factory reset from menu. I think I have factory 2 usb-a ports hub. Maybe something with enable wifi and/or ssh bringback because it won't let change wifi mode to apple carplay.
