1 - 11 of 11 Posts
Greetings all,
I'm just sharing my build almost complete will ad a few other things in the future.
current mods:
Buddy club racing coilovers
Hardrace camber arms, toe links, compliance bushings, and sway bar end links
JBR sway bars F+R, oil catch can, rear engine mount
APR extended studs
R1 concept brake rotors (drilled/slotted)
EBC Red stuff brake pads
Corksport camber plates
Ultra racing strut tower bars
iJDMtoy LED lights/fogs
Autoexe shift knob
Kenstyle paddle shifters
Gram light 57cr wheels 18x9.5 +38
The work is being done by DNAgarage a great shop!!! Highly recommended!!!
Check me out and the shop on IG:
dadventureQ
DNAgarage
I may be forgetting a few things but this is the gist of it! More to come.
Few shots of the currently in progress build.
car is done handling is great other than needing some better front camber plates I have the CS (corksport) and you can only get about 2.5 negative camber max.
I'm looking to have 3 max but capable of more if need be, also my current set up I have to run crazy rear camber so the wheels/tire don't rub so I'm looking to sale or trade my gram light 57CR they are 18x9.5 +38 with 255/35/18 I may do fender flares or just down size to 18x9 +35 RPF01 but keep the 255's.
The next modifications that I will be doing are street cams, headers, full exhaust, and a re-tune hopefully it will make upwards of 200whp+ and 200 ftlbs/tq+.
Not the best photos but you get the picture, also you can see my custom ram air which is pretty cool.
currently stock with a panel filter it dynoed 161whp and 173ftlbs/tq 2.5 s GT
dyno by Fris @ lucky7racing
https://www.lucky7racing.net/
https://www.instagram.com/explore/tags/lucky7racing/
DNAgarage has helped me out a lot with this build:
DNA Garage
https://www.instagram.com/officialdnagarage/?hl=en
It appears your fenders aren't rolled...
Is that the case?
I say roll and pull them. That will free up considerable space to accommodate that aggressive negative offset.
Sent from my LG-H910 using Tapatalk
Discussion Starter · #8 ·
Updates coming soon folks it been a minute!!! BMspec aero is almost ready to be installed I will be updating the thread soon.
Looking good. Wouldn't mind seeing details of your ram air setup. I am planning that too but I think I will cut the cowl over the grill and run a tube straight back into the filter box. How do the JBR stabilizer bars work? They are supposed to be really stiff, which is good but wondering about installation difficulty due to their thickness. I'll putting on their rear engine mount.
1 - 11 of 11 Posts
