Thanks for your answer, (I use a translator, so when I wrote I should have translated it into Spanish, thanks) I'm already collecting the parts, my car has SBS (Smart Brake Support), I also understand that I have to connect 4 wires (4 wires Ground, Power, Canbus HI and Canbus Low to the distance Radar) what is not clear to me is the diagram that you send me, I must insert them in some pin of the FBCM connectors, that part is the one that is not clear to me (I must take the cables directly to FBCM, canbus HI and Canbus Low) if you would be so kind to explain it to me that would be great, so I can do it. ThanksThis is an international forum make an effort to write in English. I don't know what you need but everything about MRCC is in this thread and "Change Configuration (explore AsBuilt" ).
Don't need to buy any harness, just attach 4 wires Ground, Power, Canbus HI and Canbus Low to the distance Radar. Prerequisite is to have SBC (Smart Brake Support) and Autohold for Stop and Go but also this feature depends on your ABS model and strategy.
Need to buy several parts including distance radar and mount bracket, emblem, steering switches and build a corner reflector with cardboard and glued aluminum foil. Change values with Forscan, perform radar alignment and reset ABS.
If you have any questions after that people in here would gladly help you.
