361 - 380 of 401 Posts
hi guys, apologies if this is the wrong place, please point me to the correct place.
Just got a Mazda CX8, it comes with all the i-Activesense features except MRCC.
So from what I read here, I would need to get:
1)Ceramic Emblem
2)Radar Sensor + Bracket + wiring?
3)steering assembly which have the MRCC controls
I tried to search around but most of the website does not have CX8 model, anyone knows if CX5/CX9 shares any parts with CX8 ?
1)Ceramic Emblem
I have retrofited my car, it working for both CX5 and CX8.
hi, was going through the list, do we need 7x "Rear Channel Upper Bolt" and 4x "Lock Support Bolt" ?
yes, you need:
  • 4x "Rear Channel Upper Bolt" to mount Radar unit to Bracket.
  • 3x "Rear Channel Upper Bolt" to mount Emblem to Mount Bracket
  • 4x "Lock Support Bolt" to mount Bracket to vehicle panel.
I have edited a image for your ref.
275801
275802
is there any possibility that the same parts also working for CX-9?
I'm not sure which model CX-9 I have since there is only one model in my country (Indonesia) and they take out bunch of i-ACTIVSENSE
yes, the most parts are the same.
Hi Guys, need help for my MRCC installation.
My car M3 2014, install radar + v/c module.
radar: GHP9-67XA1
V/C M: GHP9-67Y1X
i changed as-built as below, and also 07200401 general checksum.
07200417-BF05-1000-0016 > 07200417-BF05-70B4-204A
07200418-0000-00BF-0608 > 07200418-2845-F0BF-0665
07200423-0000-BF09-4056 > 07200423-0000-BF09-5066
after multiple SBS & ABS relearn & clear DTC, now left 4 DTC remain.
1 of them is Invalid/Incompatible Configuration which bother me.
i haven't done radar aiming yet.
===SBS/MRCC DTC C0063:54-8A===
Code: C0063 - Yaw Rate Sensor
Additional Fault Symptom:
- Missing Calibration
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Smart Brake Support/Mazda Radar Cruise Control
Freeze Frame :
-VPWR: 12.90 Volt - Module Supply Voltage
===END SBS/MRCC DTC C0063:54-8A===
===SBS/MRCC DTC C1A67:54-8A===
Code: C1A67 - Forward Looking Sensor
Status:
Freeze Frame :
===END SBS/MRCC DTC C1A67:54-8A===
===SBS/MRCC DTC C1A67:56-8A===
- Invalid/Incompatible Configuration
Status:
Freeze Frame :
===END SBS/MRCC DTC C1A67:56-8A===
===SBS/MRCC DTC C1A67:78-8A===
- Alignment Or Adjustment Incorrect
Status:
Freeze Frame :
===END SBS/MRCC DTC C1A67:78-8A===
Immortal
probably your problem is Mazda6 VCM module - Mazda 3 part nr B45A-67-Y1XG
DTC C1A67:56 [VEHICLE CONTROL MODULE (V/C-MODULE)]
System malfunction location​
Radar sensor setting information error​
Detection condition​
• The setting information sent from the radar sensor is different from the setting information of the vehicle control module (V/C-module).​
Fail-safe​
• Inhibits the mazda radar cruise control (MRCC) system control
• Inhibits the smart brake support (SBS) system control​
Possible cause​
• Radar sensor malfunction
• Vehicle control module (V/C-module) malfunction​
Fail-safe​
Possible cause​
hi rixm6, i haven't install fsc & lidar yet. could it be due to absent of them?
Maybe you could try radar aiming to erase some of the DTCs.
And check if the SBS PIDs are showing data. If so, maybe some coding modification could be needed, I will compare your codification with mine to see if there is some difference.
Enviado desde mi Redmi 6 Pro mediante Tapatalk
Hi fcoriva, unable to do aiming, SBS PIDs show data.
I read rixm6 did mrcc without fsc before, SBS need fsc & lidar.
276044
276045
